Is this hidden somewhere as my RCA outs (and assuming main outs) are being summed to mono. Normally doesn't effect me as I stream my sets online but have always wondered why when I monitored my RCA outputs it was mono. There nothing that even comes up if you enter "stereo" or "mono" in the options box yet doing a little research, apparently there IS a mono/stereo option for both RCA and MAINS! It's only accessible within Rekordbox and when I toggled them from stereo to mono to stereo IT WORKED!
Can you add this option into VDJ?
Pic shown for reference.
geposted Tue 22 Oct 24 @ 4:52 pm
I think this exists already. The DDJ-1000 Hardware Manual lists the following options (plus many others) that appear when the device is connected:
- DDJ1000-masterOutputStereo
- DDJ1000-boothOutputStereo
geposted Tue 22 Oct 24 @ 4:59 pm
This is odd as nothing for the DDJ-1000 is coming up in options.
geposted Tue 22 Oct 24 @ 5:25 pm
The prefix is "DDJ1000" and you have to connect the DDJ-1000 to see them (they get persisted to the settings.xml)
geposted Tue 22 Oct 24 @ 5:32 pm
Thanks - It is connected and working fine for the past 2 years. I'm wondering if the skin I'm using (4 channel) has something to do with those settings missing. "DDJ" brings nothing up - The mystery continues.
geposted Tue 22 Oct 24 @ 5:38 pm
ok thanks - problem solved. If you RDC into the laptop running VDJ to remote control it, it kills all the DDJ1000 options.
Case closed lol.
Case closed lol.
geposted Tue 22 Oct 24 @ 5:40 pm
