I primarily use my virtual dj account for karaoke, i always recommend your software to other kj folks looking to get into the business. I would like to ask would it be possible to add the following:
1. On the ask the dj app, when a singer sends me a song, it would be nice if the notification number on the screen stays active until that notification is removed by the kj
2. Can vdj add a setting to interact with automix and sampler, allowing sampler to override auto mix when sampler is is utilized, lowering the automix automatically to allow the sampler file to play louder. I have adjusted the sound settings to make sampler louder to play over automix.
Is there a way to allow the singer rotation list to show on the screen beside the actual karaoke screen so the singers can see the actual rotation list while waiting. I already use the options, skim, karaoke output, the most it shows are next 3 singers on the screen as a singer is showing.
Thank you in advance, love your software!
Dj gator, tucson az
Dj gator, tucson az
geposted Thu 07 Nov 24 @ 5:29 pm
