Topic: Virtual Dj and Tidal
DjReesyPRO InfinityMember since 2007
Hi People.
I've got a Problem.
Tidal is not working.
My Virtual Dj is the newest Version an I have the Dj Extension Add-On activated.
I pay 19,99 Euro every month and with other Software it works. With Serato Dj and with Algoriddim DJay it works without problems.
In Virtual Dj Every Tidal Playlist is available but I can't use any music.
If I want to load a track I get a warning "Requested quality is not allowed in user's subscription".
I hope anybody could help me
geposted Fri 08 Nov 24 @ 12:37 pm
Have you tried to Sign Out and Sign back In (right-click on Tidal folder) ?
Any chance you Sign In to some other/older account ?
geposted Fri 08 Nov 24 @ 12:41 pm
I had the same thing yesterday after signing up with Tidal again. You need to log out in VDJ then let it authorise through your browser again.
geposted Fri 08 Nov 24 @ 1:03 pm
Hi hope someone may be able to help,last night I loaded VDJ as normal open everything up went to my online music list clicked a song loaded on to deck 1 pressed play and no vocals just instrumental, this happened with every track I loaded. Never had this happen before any help what be much appreciated
geposted Sat 09 Nov 24 @ 10:46 am
Perhaps the Vocals Stem was enabled/muted ?
Check what you have in setting resetStemsOnLoad. Perhaps "All" may be a safer choice for such cases.
geposted Sat 09 Nov 24 @ 11:35 am
I've got a Problem.
I pay for the family plan
geposted Mon 16 Dec 24 @ 11:55 pm
The DJ Extension doesn't work with the Family Plan (as stated on the Tidal site).
geposted Tue 17 Dec 24 @ 9:58 am
daroPRO InfinityMember since 2024
Czy ktoś rozwiązał ten problem? Mam to samo. Playlisty, które uruchamiam na Serato na Virtualu nie mogę odpalić. To nie jest normalne.Pomóżcie
geposted Thu 16 Jan 25 @ 5:38 pm
