Hello, I would like to have a slider programmed so that it could control the effect of only one stem.
I have a button set that actives if the effects should be on vocals but it activates all the effects on the vocals and I would like only one effect dedicated to the vocals (echo).
I noticed that when I activate the button so the effect(s) is activated on the vocal stem, it cuts off the bass frequency.
So in short, can someone help me with a script that makes a slider work as the effects of echo slider 1 on only the vocal stem and for the bass frequency not to get cut off when it happens?
Any help please
Thanks in advance
Any help please
Thanks in advance
geposted Sun 10 Nov 24 @ 7:13 pm
effect_show_gui vocals echo
inspect the filter part of the fx for your bass issue
effect_active vocals echo
switch the fx on
effect_slider vocals echo 1
control the vocals effect slot, specifically echo, slider 1
switch the fx on
geposted Sun 10 Nov 24 @ 7:39 pm
Hey locodog. I cant believe its that easy. Lol. I'm not home right now but I'll try it as soon as I get home. Thanks brother
geposted Sun 10 Nov 24 @ 8:36 pm
I tried it but nothing. The only one that worked was the effect gui. Btw the parameters on the echo are to let the full bass through. When I use the echo without the 'echo stem activation' the bass doesn't get cut off.
Any ideas? Thanks
Any ideas? Thanks
geposted Sun 10 Nov 24 @ 9:22 pm
