Topic: Sampler cues
The sampler options differ on my decks for some reason. I just wanted to know how I can change them so it can match. Just to be clear I'm not talking about sampler packs, I'm talking about the samplers on the action pads. So how can I change them to make it match on both the decks ?
geposted Fri 15 Nov 24 @ 12:12 pm
If your sample bank is limited to 8 samples then both decks will show the same samples
geposted Fri 15 Nov 24 @ 1:03 pm
How do I check if it is limited to 8 ?
geposted Fri 15 Nov 24 @ 1:29 pm
I suggest counting.
geposted Fri 15 Nov 24 @ 3:32 pm
geposted Sat 16 Nov 24 @ 3:45 am
FYI, this has been changed in the new version that will be released soon, and will now work as you expect.
(this behavior was a leftover from the early sampler days when people used dedicated "16 pads" MIDI controllers to control their sampler. before the first controllers with pad came on the market. Obviously in 2024 most controllers have 8 pads on each decks, hence the upcoming change)
geposted Sat 16 Nov 24 @ 7:49 pm
Can you give a little more detail on how it will work?
If I have a bank with more than 8 samples, what happens? How/where will they be displayed?
Does this mean banks will be restricted to 8 samples? I like the way it works now. I have many banks with 16 samples and can access them from my 16 pads (8 per deck).
geposted Sun 17 Nov 24 @ 10:45 am
Anyone? Anyone?
geposted Fri 22 Nov 24 @ 1:25 pm
You will be able to scroll through the pages, so actually it will be easier to manage banks with more samples
geposted Fri 22 Nov 24 @ 1:35 pm
