When i load in a track of 175 bpm that drops at 0:44 but i want to play it at 185 bpm for example i use the bpm slider to change it but then the song timing also changes. Then the song drops at 0:41. Is there a way to change this so when i change the bpm of a song, the song still drops at 0:44
geposted Sun 17 Nov 24 @ 9:20 am
Well that's not really possible, is it?
If you alter the speed of the track it will change the play time.
geposted Sun 17 Nov 24 @ 9:34 am
I know when you change the bpm on rekordbox the song timing changes too. So there is no way to do this on VirtualDJ?
geposted Sun 17 Nov 24 @ 9:46 am
It's impossible, because the length of the track (and therefore the time location of a drop) is a result of its tempo. If you make the track faster, it becomes shorter, because the beats are closer together.
If you're driving to a destination that's a fixed distance from you, driving faster gets you there quicker. Same principle.
geposted Sun 17 Nov 24 @ 10:26 am
Yeah i get how it works. Thx for helping!
geposted Sun 17 Nov 24 @ 10:50 am
