Topic: Script Question - blue sky
Hi guys,
Would it be possible to script a command that forces Automix to never play the same song twice?
I could do it in VB script with VLC but not in VDJscript. Just wondering if it could be possible?
Thanks
Mike
geposted Mon 18 Nov 24 @ 4:06 pm
automx has a remove duplicates button.
geposted Mon 18 Nov 24 @ 4:16 pm
Yes, as you know is a big but, multiple entries and all that means that not all duplicate songs are duplicate songs.
M
geposted Mon 18 Nov 24 @ 4:57 pm
Sound like a tag issue, a not very difficult one, but subjective to what you want.
You have tags, you have string variables, you can append string variables, you can do a contains check, nothing hard there.
geposted Mon 18 Nov 24 @ 5:22 pm
