Topic: licence broken
i have an active license and the system is unstable because it says the license is broken
geposted Wed 20 Nov 24 @ 10:16 pm
Support Staff wrote :
something is blocking VirtualDJ from connecting likely.
If you can not connect (and its not something else, like wrong password).
If you already tried the tool [ For PC: For Mac: ], then check your firewall etc..
If unsuccessful you can contact Support Team here, so they can help you with remote access
https://virtualdj.com/help/
geposted Wed 20 Nov 24 @ 10:18 pm
