Dear Virtualdj team,
I've been having such a terrible time recently and quite scary. Thankfully I've got some back ups.
Basically on occasions when I saved virtualdj either via database back up or saving folder my cuepoints database was wiped. I have got no idea why. This definitely scared me. Have you got any explanation why this has been happening to me?
I'd also like to ask what is better between doing regular database back-ups or saving the entire Virtualdj folder on my USB drive?
Please help me overcome this problem as it is terrifying.
Thank-you
Jav
Thank-you
Jav
geposted Tue 26 Nov 24 @ 2:02 am
Usually if the database can not be found [so appears blank] it's a case that a vdj process didn't close correctly and hasn't release the database, first thing to check is task manager way down the list, close all instances of vdj there and then try open the app again.
geposted Tue 26 Nov 24 @ 3:07 am
Ok Locodog thank-you I'll try and see how I get on
Javvvvvvvvvvvvvvv
Javvvvvvvvvvvvvvv
geposted Fri 29 Nov 24 @ 12:20 am
Loco I have one question. Is it better to save virtualdj database via the backup facility or saving the entire folder on my USB drive?
geposted Fri 29 Nov 24 @ 12:46 am
1
geposted Fri 29 Nov 24 @ 1:53 am
What did you mean? Sorry
geposted Sat 30 Nov 24 @ 8:22 pm
geposted Sat 30 Nov 24 @ 9:07 pm
Thank-you soooooooooooooooo much. Will do
geposted Sat 30 Nov 24 @ 11:58 pm
Heyyyyyyyyyyyyyyyyyy
Ohhhhhhhhhhhhhhhh my goodness I'm having the same problem as last week. My virtualdj database has went completely blank. I'm completely convinced that it's not reading the database back-ups I've made properly as half of my cuepoints songs aren't there. I've tried restarting my PC and still the same thing. What should I do?
geposted Sun 01 Dec 24 @ 1:02 am
When you close Virtual DJ, it should save the live copy of the database. That can take a bit of time depending on its size and the computer and disk. The backup process is something different - Virtual DJ can take a copy of the database and write it somewhere else as a backup.
It’s the first process that can cause the database to appear blank if it doesn’t finish writing the database.
That’s my understanding of how it works.
geposted Sun 01 Dec 24 @ 1:47 am
Heyyyyyyyyyyyyyyyyyy I've got the database back again. Something weird happened seriously. Do you think I should store multiple back-ups in this situation?
geposted Sun 01 Dec 24 @ 2:23 am
It’s generally a good idea to retain multiple backups and delete them after a time that you feel comfortable with.
geposted Sun 01 Dec 24 @ 5:50 am
Thank-you so much Phily
geposted Sun 01 Dec 24 @ 8:05 pm
So you suggest just to frequently back up the database through it's facility instead of copying the entire folder on my usb? Please confirm one last time
geposted Mon 02 Dec 24 @ 12:26 am
I’m probably not the best to ask as I just take copies of my databases and settings files (I have all my media on a second internal drive so there’s a second database in its \VirtualDJ folder). So that works for me. Others like the program’s built-in backup facilities, which were introduced to make backups easier for people.
geposted Mon 02 Dec 24 @ 4:34 am
Thank-you Phily
geposted Mon 02 Dec 24 @ 7:24 pm
