Topic: Rane Performer "Issues" - Page: 1
Hi, why when I press Cue button the jogwheel motor starts to work? It is suppose that it has to work when you press play button. On the other hand, If you configure loop adjust for looping as Serato do it, the waveform does not stop and it makes difficult to adjust the loop. Is there anyway to fix this 2 "issues"?
Thanks in advance.
geposted Wed 27 Nov 24 @ 2:48 pm
No body can solve this? When I load a track if I push CUE boton the motor start to turn, and there is another issue, If you load a song on channel 1 with fader down and you have another song on channel 3 with fader up, the song on channel 3 stop itself... I don't understand this issues... I'm paying a pro license and it is imposible to make a session without issues.
geposted Sat 30 Nov 24 @ 6:09 pm
Please take a look at cueMode option in the User Manual
geposted Sat 30 Nov 24 @ 11:33 pm
For understanding multideck use, please take a look at the hardware manual for the Rane Performer.
geposted Sun 01 Dec 24 @ 12:39 am
geposted Sun 01 Dec 24 @ 1:33 pm
That behavior does seem a bit odd to me on load. The mapping of the button is based on cue_stop:
cue_stop & set 'cuestop' 1 whilepressed
Play/Pause also references that variable
play_pause & set 'cuestop'
I just tried using those mappings on a pad controller with cueMode = cue and it seems to work as expected (I don't own the controller/have the controller on hand personally to teat it there.
  • What version of VirtualDJ are you using?
  • Did you do any remapping of those buttons, or do you have any special mapping for ONSONGLOAD for that controller of the keyboard?
Just reasonable questions to ask about the situation. It might actually be a bug (the devs probably have more to say on this).
geposted Sun 01 Dec 24 @ 7:34 pm
Thank you for your support. I have the last version available 8462.2119 (I have activated early updates). It happens from the beginning, I have been using factory default mapping and happens the same.
The mapping for cue button on factory default is:
cue_stop & set 'cuestop' 1 while_pressed
I have no special mapping ONSONGLOAD. Please, could you elevate the case to dev team? If you need that I test anything, just tell me.
geposted Sun 01 Dec 24 @ 8:04 pm
geposted Sun 01 Dec 24 @ 11:34 pm
What is the problem you are having exactly when the motor starts when pressing cue btw?
geposted Mon 02 Dec 24 @ 4:46 am
It is not just to start, the problem is the motor starts and the song starts too as if I had pressed play... have you seen the video? To solve this, I have to press play (then vdj understand properly the song is playing) and reset the cue. When I load a song a this happens in a middle of a session... is not the best way to have a decent session.
Please, have a look to the video for your understanding.
https://share.icloud.com/photos/0b0XnSZQBw8K2H1gmPHLHbW_A
geposted Mon 02 Dec 24 @ 7:55 am
Just to be sure, you are using the factory default mapper for the controller?
geposted Mon 02 Dec 24 @ 8:18 am
Yes, I’m using factory default mapping.
geposted Mon 02 Dec 24 @ 8:53 am
I just checked, and the CUE button on the Performer doesnt start the motor, until you press the PLAY button.
In your Account Stats, we see ..
Mapper: RNPERF=Rane Performer - Mapeo Personalizado:
so please double-check in Settings->CONTROLLER if the Performer is using the "Factory default" Mapping
If this is still an issue, perhaps it's some setting that cant tell at the moment , so try to Reset from OPTIONS tab of Settings and check again.
geposted Mon 02 Dec 24 @ 2:43 pm
Hi DJDAD, I deleted my custom mapping and I reset Options from tab settings... the same happens. Please, you can check this on the link below, I recorded a new video.
https://share.icloud.com/photos/0f4T9AhMzccI4kkQQbrDaD5kA
geposted Mon 02 Dec 24 @ 4:02 pm
Thats weird.
And what you show in your video is the behavior right after the 1st Trak is loaded to a Deck , without anything else enabled/pressed etc ?
EDIt.. OK, i see, it happens on the first Track you load on the Deck, but then the next loaded Tracks work fine ?
geposted Mon 02 Dec 24 @ 4:59 pm
djdad wrote :
Thats weird.
Yes it is like that, the first track I load make it happens and there is another casuistry that make it happens too, but I couldn't simulate the issue again, I think it is something strange when you leave the track to finish itself with stem split activated or something like that... But I'm not sure about this casuistry. Maybe if you could repair the first issue, the last I mentioned will not occur anymore.
geposted Mon 02 Dec 24 @ 6:24 pm
Starting from the Factory default Mapping, locate the Key named as MOTOR_ON_INSTANT and change its action from ...
var 'RNswapdecks' ? loaded ? timecode_active ? off : linein ? off : get_ns7_platter 'on' : off : var 'cuestop' ? on : send_nothing
to..
var 'RNswapdecks' ? loaded ? timecode_active ? off : linein ? off : get_ns7_platter 'on' : off : var 'cuestop' ? get_ns7_platter 'on' : send_nothing
Then restart VirtualDJ and see if the issue on 1st Track is still there.
geposted Mon 02 Dec 24 @ 9:49 pm
to..
Hi! Thank you so much for your support! Now it works perfect. I will test it deeper later but I think now it is fixed.
geposted Tue 03 Dec 24 @ 6:35 am
to..
Hi, after test it during yesterday I can conclude it is fixed. Are you going to make that change on factory default mapping?
Thank you very much, your support was very useful.
geposted Wed 04 Dec 24 @ 9:20 am
Yes, change will be offered in next update to the default Mapping
geposted Wed 04 Dec 24 @ 2:37 pm
95%
