Hello,
The cue points on my S11 screen are not always showing up. The issue seems to be on a track-by-track basis. The cue points functionally work, but don't show on the song overview waveform or in the scrolling waveform on the S11 screen, but do show up on the computer GUI. The issue persists after restarts, with the same songs. I can't find any difference between the songs that do work and the songs that don't (file type, hot cue type, hot cue color set or on auto, database entries look similar).
I found an anecdote from someone else about the same issue: https://old.reddit.com/r/PioneerDJ/comments/17qlbl2/virtual_dj_and_the_djms11/krl14ug/
Any assistance or debugging advice is appreciated.
Thank you!
Thank you!
geposted Thu 28 Nov 24 @ 6:49 pm
I've also noticed this (just didn't make a report on it).
geposted Thu 28 Nov 24 @ 6:52 pm
Me too, if someone find solution will be great 🔥
geposted Mon 02 Dec 24 @ 8:58 pm
