Is it possible to get an auto sync feature? Where you press play and it auto syncs it to the closest 1, 2, or 4 beats. Most modern software like Rekordbox and Mixxx have this already.
Also, is there a modern redesign of the UI in the works at all?
Thanks!
Thanks!
geposted Tue 03 Dec 24 @ 1:48 am
It's called smartPlay in settings, it is dependant on globalQuantize setting value.
geposted Tue 03 Dec 24 @ 3:46 am
Looks like the “4-beats" value disappeared (or is just missing)
I read here https://www.virtualdj.com/forums/action/newpost.html?topicid=236284"eid=1986469 to just key in “4” and that works indeed, but it would be more user-friendly to add "4 beats” in the dropdown list of acceptable values.
geposted Wed 04 Dec 24 @ 5:30 pm
Awesome thank you
geposted Sun 15 Dec 24 @ 8:14 pm
I've been using this smartPlay command since VDJ 8 was released 10 years ago. See below;
Programming Various Controllers For Beatmixing In VirtualDJ.
General usage
I have programmed with script some actions that I regularly use in a 'live' situation. I am an open format DJ and through the course of a gig I may drop into beat mixing for say 20-30 minutes then move onto not beat mixing for other parts of the gig. I originally created these mods when VirtualDJ 8 was first released in May 2014, I then adapted similar actions to all my subsequent Controllers. I also programmed a Pad Page with these commands.
Denon MC6000 Mk1 & Mk2 Mapping Mods
Shift + PLAY - to switch SmartPlay on/off
var '$shift' ? holding 500ms ? goto_first_beat : smart_play : play_pause
Shift + VINYL - pitch reset slowly, double press resets instantly
var '$shift' ? pitch_reset : vinyl_mode
Shift + CUE - pitch lock on/off
var ‘$shift’ ? pitch_lock : cue_stop
DENON MC7000
Shift + CENSOR - to switch SmartPlay on/off
pitch_reset
SLIP - pitch lock on/off
pitch_lock
Other Controllers I programmed the mappings on were the original Pioneer DDJ1000 and a Roland 707m that I owned for a short time.
Have Fun, Cheers.
General usage
DENON MC7000
pitch_reset
pitch_lock
Have Fun, Cheers.
geposted Mon 16 Dec 24 @ 4:04 am
