Hello,
My main use for Virtual DJ, right now, is when I'm announcing my son's games. I have set up a few folders in samplers for quick access to some effects I need. I'm currently using the base performance layout with 4 decks on a MacBook, no external interface or control device, just trackpad and keyboard. I have noticed that each deck shows the same sampler folder. If I want to switch to another folder, all of the sampler pads on each deck change to that folder. Is there a way to have the samplers in each deck individualized so they don't all change to the same folder?
geposted Tue 03 Dec 24 @ 10:16 pm
After a little looking, I found my answer in the Sampler options folder in the Settings.
geposted Tue 03 Dec 24 @ 10:27 pm
