Hi guys, I DJ at multiple night clubs using the club's controllers and standalone, so it is often necessary to hit Analyze BPM etc. when something about the hardware throws off the defaults, for example, using an Opus Quad it turns off the gain since all the EQ, FX, etc are all hardware based, but when returning to a Denon SC Live 4, where all the EQ, FX, etc are software, none of the auto gain settings are restored. I have added anchor points on POIs Editor to avoid the Beatgrid from getting thrown off (half of the Reggaeton songs are analyzed incorrectly). I'm trying to find a proper method so that the Anchor doesn't get deleted on the next Analyze.
In other words, is there an anchor point that won't be deleted on the next Analyze?
geposted Fri 06 Dec 24 @ 10:27 pm
You don't have to reanalyze anything. That doesn't do anything regarding applied gain.
Once the opus quad is disconnected or vdj is restarted without it connected, the gain will be applied in software again
geposted Sat 07 Dec 24 @ 2:39 am
