hello,
the "instrument echo" fx is nice but it will really echo then mute both instruments + base leaving only voice. Would it be possible to mute only instruments+bass leaving voice and base instead ? I see that, for the "beatgrid" fx, is possible to modify its grid; is it possible then to customize the other stem effects in some way so, for example, selecting what stem to send to echo, or echo length, or feedback.. ? Could this "pure instrument echo" fx be realized using/triggering a script ?
Thanks.
Thanks.
geposted Sun 08 Dec 24 @ 8:39 am
You can edit the pad page. Currently the instrument echo out uses "stemfx:MeloRhythm", but you could change it to "stemfx:Melody"
geposted Sun 08 Dec 24 @ 9:20 am
Hello Adion,
thanks for answering, but, sorry, i cannot find how to modify the pad page,
geposted Mon 09 Dec 24 @ 9:24 pm
geposted Mon 09 Dec 24 @ 11:44 pm
Wonderful!
Thanks a lot!
Thanks a lot!
geposted Tue 10 Dec 24 @ 2:43 am
