once i start scratching i would love a option to have master tempo disable during that time and enables when im done scratching .. it would save me time as a trick mix open format dj
geposted Wed 18 Dec 24 @ 4:05 am
master tempo is not used while scratching already
geposted Wed 18 Dec 24 @ 6:05 am
o thank you but is there a way to keep it off while using the pitch at the same time while scratching ?
geposted Wed 18 Dec 24 @ 7:18 am
VirtualDJ already seems to smartly disengage Master Tempo while scratching.
Not sure what you mean my "keeping it off while using the pitch while scratching". Maybe just turn master tempo off and scratch (most turntablists don't use Master Tempo in their routines anyways).
geposted Wed 18 Dec 24 @ 5:06 pm
