Topic: Sound gap settings
Hi everyone.Do we have any solution about the gap in the sound that it makes when we push apply in the sound settings?When i have an older macbook (2014 with macos high sierra) i didn't have this problem with any change in the sound settings.
geposted 16 hours ago
If you're referring to windows then that buttons resets the drivers so of course there is going to be a gap.
For example if i play with djm900 at 1-2 line and i want to change to 2-3 when i do the change at sound settings and push apply it does a big gap at the sound.But with my older pc i didn't have this.
geposted 14 hours ago
Well you got lucky with your old machine, refreshing audio config it is completely expected that there is a small break in the sound.
It's just not something you should be doing in performance.
