Hi, I'm trying to use the scratch button to switch the deck, left deck for deck 1 or 3, and right del for deck 2 or 4. without use the shift button (shift + scratch), default option. something directly.
And I Know this work:
Deck right & deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck :
Deck left & deck 1 leftdeck ? deck 3 leftdeck : deck 1 leftdeck :
both work well separately, but I need they work together without affecting each other.
I saw someone doing directly on YT using serato. but I love Virtual DJ. is it possible? someone can help me?
geposted Sun 12 Jan 25 @ 1:51 pm
SHIFT+SCRATCH are defined in a special way because they allow you to change decks on the controller.
You can try the following mapping on SCRATCH button and see if it works:
action_deck 1 ? deck 3 leftdeck : action_deck 2 ? deck 4 rightdeck : action_deck 3 ? deck 1 leftdeck : deck 2 rightdeck
geposted Mon 13 Jan 25 @ 7:34 am
