Topic: Color FX editing parameters
Hi. Where are the editing parameters for the color FX knobs under the EQ knobs? As far as I can tell, only the deck effects parameters can be edited. The color FX can be changed (filter, echo, etc) but I cannot find any way to edit their parameters (echo strength, filter resonance, etc). Seems like there ought to be a way to adjust them.
Thanks
geposted Tue 14 Jan 25 @ 3:18 pm
effect_show_gui colorfx
some params are linked to the colorfx dial so there's no point changing those.
geposted Tue 14 Jan 25 @ 3:39 pm
Could you detail the process to apply that script? I'm new to this script thing.
geposted 4 days ago @ 5:21 pm
not really, script button, press button, move sliders, check main color_fx dial doesn't change sliders.
geposted 4 days ago @ 7:44 pm
