Just a simple question, but I can't figure it out. How do I add code in a topic in like a code segment wich is easy to copy for for instance Python scripts or other kind?
I want to do a topic on some stuff but i need to add some code for it, wich i think is better when it is in a code windowed part...
and how can I set my settings to get updates if someone has reacted to me?
greets and thanks in advance
geposted Sat 18 Jan 25 @ 10:36 am
There's a code </> icon when you create a post at the bottom.
geposted Sat 18 Jan 25 @ 3:28 pm
ok, thank you
geposted Sun 19 Jan 25 @ 6:09 am
