Hi anyone know the script to keep bpm on same deck when loading new track ( no track on other deck) thanks
geposted 13 hours ago
before loading, save the bpm to a variable
set savedBPM `get_bpm & param_cast beats`
load the next track
recall the variable and cast it to pitch verb
get_var savedBPM & param_cast pitch
there's a few ways this could be implemented [button press, rsi, onsongload] but you haven't given enough details to get a specific solution.
load the next track
geposted 11 hours ago
Thanks loco dog- in practice id like to use this to play one deck and use sampler backbeat (hence needing the bpm to maintain on next track load) whilst using other deck to scratch freestyle - so could use as a custom button for that particular track ?
Tia
Tia
yeah just slot in a load command between the two commands above.
