Hello, I don't see Gain on the Denon Prime 4+, can it be entered so I can see it on the console screen?
geposted Tue 21 Jan 25 @ 6:25 pm
not a answer to your question but I just purchased this controller. Ay issues I should be aware of when using ADJ?
geposted Fri 24 Jan 25 @ 4:50 pm
Surely you should be asking these questions before you purchased it?
geposted Fri 24 Jan 25 @ 4:55 pm
work ok, but i dont see Gain ...
geposted Sat 25 Jan 25 @ 2:05 pm
Why do you need to see gain on the screen? VDJ has autogain (default recommended setting) and the Prime 4 has gain knobs.
geposted Sat 25 Jan 25 @ 2:16 pm
hello, because not all songs are at the same volume
geposted Sat 25 Jan 25 @ 2:23 pm
Hence autogain.
geposted Sat 25 Jan 25 @ 2:32 pm
groovindj wrote :
Hence autogain.
Ok thanks
geposted Sat 25 Jan 25 @ 9:23 pm
