I use VDJ with videos, sometimes I have to use Audio files. On the configuration panel I assigned "Audio Only / Shader". But I can´t change the shader, and the "Auto Change" option is check. Also when I click on Shader in the principal window and I try to change the shader, the bar shows the shader´s name, but in the video window I just have a black screen
geposted 3 days ago @ 3:18 pm
