Prime 4 plus question, I am looking to assign and map the second performance pad page no2 pad 4 to stems using P4plus and VDJ. I have edited the mapper file to the correct command but it not change the button to do what i need. Is there something within the software that i also need to make it work??
here is the change i made to the mapper file
<map value="PADMODE_SLICER" action="pad_page 'sampler' ? pad_page 'Stems' : pad_page 'sampler'" />
geposted Sun 02 Feb 25 @ 2:58 pm
You don't need to change mappings, just reassign the pad page.
geposted Sun 02 Feb 25 @ 3:51 pm
how do i do that ?
geposted Sun 02 Feb 25 @ 4:07 pm
Details in the user manual.
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads/index.html
geposted Sun 02 Feb 25 @ 4:25 pm
