Hi all,
Does anyone know of a way to manually set the fade-volume curves in Automix transitions?... specifically, I would like to fade in the next track, but not fade out the previous track...
Any ideas welcomed!
Cheers, Or
Any ideas welcomed!
Cheers, Or
geposted Sat 08 Feb 25 @ 9:25 pm
Automix editor allows you to do this manually
geposted Sat 08 Feb 25 @ 10:00 pm
Could you please point me as to where?... I totally looked anywhere I could think of, including Automix editor, menus, right-clicks, hovering... :-) but couldn't find any place to manually control the volumes' cross-fade in the transition phase... any help would be highly appreciated!
Cheers, Or
Cheers, Or
geposted Sun 09 Feb 25 @ 6:34 pm
... just and to explain my needs maybe a bit better :-) in the transition phase of Automix, I don't want the 2 tracks to simply crossfade linearly in&out over the (blue) transition block, but control it manually - for instance: fade-in the next track, but keep the outgoing track in normal volume till it's end.
Thanks again for any help! <3
Or
Or
geposted Sun 09 Feb 25 @ 6:37 pm
I'm also interested in that funcionality. If anybody has a way to do that; it would be great. :)
geposted Sat 15 Feb 25 @ 7:48 pm
