I just have a quick question. When I have several filters active then toggle one of them I get different results. So when I deactivate one the rest are triggered automatically?
geposted Thu 13 Feb 25 @ 12:41 pm
Assuming the filters have different parameters, then of course the results will be different if you enable or disable them.
geposted Thu 13 Feb 25 @ 2:07 pm
So it is a yes.
geposted Thu 13 Feb 25 @ 2:09 pm
I wanted to be certain since I haven't been using the feature until recently so understanding its behavior is critical when doing combos
geposted Thu 13 Feb 25 @ 2:11 pm
Filters are covered in the manual:
Read Me
They're not mutually exclusive. If you enable one then one is active. If you enable another, you have two active.
Read Me
geposted Thu 13 Feb 25 @ 2:20 pm
