I’ve been using an M1 Mac with VDJ without any issues and successfully used it with a Rev5 last Thursday. Yesterday, I was using my DDJ-1000, and everything was working fine until I tried changing some jogwheel display settings. I had my 2014 Mac connected to the controller for comparison and noticed that some DDJ-1000 settings weren’t displaying the same way on the M1 as they did on the 2014 Mac.
I initially suspected an OS issue since I had installed the latest update earlier in the week. However, after restarting the M1, it wouldn’t reconnect to the controller. I then tried reinstalling the audio drivers and firmware, but that didn’t help.
Today, I attempted to connect the Rev5 again, but it’s not working. I also tested the DDJ-400, and that isn’t connecting either - no signs of the soundcard for any of my controllers and no response from them.
However i did install serato a while ago and it shows my rev5 is connected and i'm able use use it and based on this experience it has lead me to conclude that this is a VDJ issue where the latest mac update (which is a security update) is blocking the connectivity in VDJ with these controllers.
geposted Sat 22 Feb 25 @ 11:21 pm
With latest update i'm getting notifications every time I connect a controller to allow it to access the USB device. Maybe you aren't getting prompts and it is just blocking it being accessible. Check you security settings for USB.
geposted 4 days ago @ 9:24 pm
At first it was all fine for about a week and then just 1 day while connected to the ddj 1000 and trying to change a hardware setting the mess began. So after a while I wasn't getting anything like what u mentioned and the prompts have always been there. It just stopped connecting to any device.
geposted yesterday @ 12:34 pm
What settings did you mess up with ?
Check disableBuiltinDefinitions setting and make sure it's set to NO
geposted 10 hours ago
