Hello friends of the best DJ software in the world
I bought the Kaoss-Replay and I think it's a pity that you can't fire the effects and samples separately (different audio channels) from each other.
So the samples created in VDJ have to be used and am now trying to map the Kaoss replay in order to at least be able to use the pads. But I am an absolute mapping beginner and wanted to ask here times if there are any plans to integrate the device into VDJ and / or if someone has already made a start and could share it with me.
Greetings from Berlin
geposted Tue 04 Mar 25 @ 7:52 pm
reading the midi table
https://www.korg.com/download/global/html_manual/kaossreplay/us/index.html#!/16-02_01
It doesn't look too involved (compared to other devices)
If you follow the bit about
How to get the Unique Identifiers :
https://virtualdj.com/wiki/ControllerDefinitionMIDI
With the VID & PID (send me the midiLog) I should be able to get something started.
geposted Tue 04 Mar 25 @ 8:29 pm
Hey LocoDog
Thank you for taking care of me.
I will submit the requested item soon and ask for your patience as my job requires a lot of time at the moment.
Thank you from Berlin
geposted Wed 05 Mar 25 @ 8:03 pm
Hey LocoDog
<?xml version="1.0" encoding="UTF-8"?>
<device name="Kaoss-Replay" author="DJ-EXELBONSAI" description="Kaoss-Replay" type="MIDI" decks="1" drivername="Kaoss-Replay 1 PAD" drivernameout="Kaoss-Replay 1 SOUND" vid="0x0944" pid="0x0212" sysexid="F07E??0602427800000000000002F7">
</device>
This is what I hope I have found correctly so far.
The Kaoss is recognised as such in VDJ.
</device>
geposted Thu 06 Mar 25 @ 6:35 pm
That's enough to get me started, thank you.
Defining should be pretty straight forward, mapping we start getting into personal preference.
Please check PM.
Please check PM.
geposted Thu 06 Mar 25 @ 6:42 pm
Unfortunately, nothing has happened yet! Will the programmers at Atomix ever look into it? The Replay is selling very well and is in widespread use.
geposted Fri 07 Nov 25 @ 3:05 pm
