Topic: Sample editor bug?
When I go in the browser to sampler > per-song > a song I see the list of samples as expected.
I then right click and go to sample editor because I want to rename them
After saving, the name hasn't changed, the icon has change to a musical note (rather than a loop) and the sample is unresponsive in the editor, though it does still work in the sampler pad
geposted Thu 06 Mar 25 @ 12:49 am
I'm sure I made a similar comment about this in the past. You may also notice that the samples don't appear in the sidelist sample window unless you have pad mode selected. In list mode it's blank.
Additional issue with this, thanks for pointing it out.
Earth to VDJ Support...does anyone read or respond to these?
Should be fixed in current Early Access build (8553)
