This Plugin does not seem compatible with this version of virtual dj is the message I received when I try to use some plugins I downloaded from the site. I had got another laptop that's running windows 10 and I get this message now. Can anyone help me out? So I need to update something? I have the latest version of Virtual dj.
geposted Tue 11 Mar 25 @ 12:53 am
If you've downloaded 32 bit plugins in the past and you have since updated to 64bit version of VirtualDJ, those older 32 bit plugins won't work.
Other than that, can you please provide examples of which plugins/effects don't work for you ?
geposted Tue 11 Mar 25 @ 9:38 am
So for I've only messed with the twin pan and BFX Delay lowkill.
So what will be the fastest and easiest way to fix this?
geposted Wed 12 Mar 25 @ 12:53 am
Download and install the 64 bit versions of those effects.
For instance BFX Delay https://www.virtualdj.com/plugins/index.html?addonid=81170 is available both as 64 and 32 bit plugin.
So, if you used the 32 bit before, you should install the 64bit now
geposted Wed 12 Mar 25 @ 11:57 am
Whenever I download the BFX Delay and install it. Im still getting the same error message. I go to setting in Virtual Dj and Extensions and so on to install the app and I get the same message. Is there a certain way to picj which version I wanna install 32 or 64 or Does VDJ automatically pic the right version for me?
geposted Sat 15 Mar 25 @ 3:16 pm
Pick excuse my spelling. This phone sucks.
geposted Mon 17 Mar 25 @ 10:56 pm
Thanks for the info
geposted Thu 20 Mar 25 @ 1:12 am
