hi all.. is it possibile to sync the entire "history" folder on clouddrive?? because if a select the entire folder on the side menu does not appear the "sync to clouddrive" option.. but if i select a sub folder , example "2024" folder it gives me the option to sync the "2024 folder"...
is there a way faster than to sync each singular year folder?
can i suggest to developer to add the "sync to clouddrive" option on the side menu? thank u all for help
geposted Fri 14 Mar 25 @ 4:29 am
Yes, I'd like to sync my entire history as well!
(and M3U Playlists, while you're at it.) Thanks!
geposted Sat 13 Sep 25 @ 2:38 pm
