Topic: no connection to the server
hallo , ich habe die neue Version von VDJ runtergeladen . beim anmelden meiner Pro version kommt die Meldung ,,keine verbindung zum server....., obwohl der Lappi internet hat.
Wer kann mir helfen. kann mich sozusagen auf Lappi nicht anmelden
geposted Sun 16 Mar 25 @ 12:21 pm
If you're getting that message, it's usually because you've had a cracked copy of VDJ on your system, which disables the connection.
You need to edit the hosts file on your computer to remove the block. Details in the VDJ wiki pages.
I have the same Problem. The tool doesn't fix the issue.
It is also not possible to acquire a license.
