Hello, is there any way, using VDJ Script, to save a named loop in a slot? For example, "Start-Loop" in Slot 1 as a Saved Loop.
loop_save X & cue_name "Saved Loop X" "Start-Loop"
Doesn't work now.
Is there another way to rename a Saved Loop? or is there a way to assign a Saved Loop a slot? (using VDJ Script)
Thanks in advance.
Doesn't work now.
Thanks in advance.
geposted Tue 25 Mar 25 @ 11:56 am
I love how people make up stuff
cue_name 1 loop "Start-Loop"
cue_* verb [INDEX NUM] [TYPE TO INDEX] [LISTED PARAM]
geposted Tue 25 Mar 25 @ 12:17 pm
Sorry Locodog but I can't make it work.
I'm trying:
loop_save 2 & cue_name 2 loop "Second"
but shows strange behaviour.
I want to save the actual selected loop on the second slot with the name "Second".
Can you tell me how to do it?
I'm trying:
geposted Tue 25 Mar 25 @ 1:33 pm
call saved loop by name, delete cue by name, save current loop to slot.
geposted Tue 25 Mar 25 @ 1:46 pm
Sorry to bother you again, Locodog, but I’ve tried every combination I could think of, and none of them worked properly.
Could you please provide the exact code needed to save the currently active loop into slot 3 with the name "My Loop 3"?
Thanks for your help.
geposted Wed 26 Mar 25 @ 7:25 am
Can anybody help me?
geposted Fri 28 Mar 25 @ 9:43 am
It's not possible?
geposted Mon 31 Mar 25 @ 2:52 pm
