Hi
I have flx4
after inver deck from 1 to 3 on or 2 to 4
fx on, beats+, beats- work with shift button pressed all the time
After restart everything works correctly till invert_deck
Has anyone had this problem?
I have flx4
geposted Mon 31 Mar 25 @ 7:38 am
Have you mapped some button (or SHIFT+button) as invert_deck on your FLX4 ? If so, which one ?
geposted Mon 31 Mar 25 @ 7:58 am
Hello
For changing deck from 1 to 3 i use left shift+ left load
for changing 2 to 4 right shift + right load
command is simple 'invert_deck
After this
fx buttons (fx_on, beats-/+), crosfader, smart_fader, smart_color and mic_volume knob work as if the shift button was pressed all the time. Other buttons work normal.
thanks for the answer
After this
geposted Mon 31 Mar 25 @ 3:27 pm
Thank you
Change deck by button without shift working well
geposted Mon 31 Mar 25 @ 8:07 pm
