I have the same problem as on this topic: https://www.virtualdj.com/forums/249845/VirtualDJ_Technical_Support/Denon_DJ_Prime_Go_Headphones_Volume.html
So when I click on cue on the Denon Prime Go, the headphone volume is always at 100%. I have to turn up the level knob, and then down, to get a lower volume.
I'm using Engine version 4.3.1 (but had the same problem on older versions like 4.2), and VirtualDj version v2025 b8528.
The fake_hp solution in the other topic doesn't work for me (or I'm doing it wrong).
The headphone volume knob works fine when using Engine (so without Virtual Dj) so it's not a hardware issue.
geposted Fri 04 Apr 25 @ 1:26 pm
I noticed that yesterday as well. The headphone volume using VDJ on the Prime Go+ was probably double of what it is in standalone using Engine.
geposted Fri 04 Apr 25 @ 1:33 pm
Also strange, it has always worked fine on my Prime 4. It's only a problem on the Go.
geposted Fri 04 Apr 25 @ 1:46 pm
