I would like to delete files from VDJ's browse by exploring my folders, is it possible to do it with the mouse, selecting from the menu, I would like to assign this function to a keyboard key, I can't find a command that says browsed_file_delete. How can I do it?
geposted 12 hours ago
There isn't a script to do that because all kinds of mischief could be done by malicious users sharing nasty scripts and a lot of users just don't know how to read script.
I have a windows plugin that calls the application button [not on keyboards that much any more] that calls context menus and then it uses browser_scroll browser_enter to pick from the options.
If you want that I can share over pm but I can suggest a better safer way
Button/key
Filter
So you mark tracks with your button, but it doesn't delete them, but you visit your filter and if you're absolutely sure you can select all and delete all marked tracks in one go
Button/key
browsed_song color "#000101" ? browsed_song color "none" : browsed_song color "#000101"
Filter
Color is "#000101"
geposted 11 hours ago
thanks I understand, I will continue to do it manually :)
