I've got Shaders on for non-video files but it changes to a new one after like 15 seconds. How can I change how long it takes to auto-change to the next one? (Screenshot below)
Also if I don't like a Shader that came with VDJ how can I delete it? I can't find the folder where these are saved to
geposted Thu 08 May 25 @ 1:28 pm
delete from the list you see there, right click.
Auto Change triggers when the deck rolls round to beat 1 of 32, so at ~128bpm is ~15s
Windows I have a plugin that can change that to different beat lengths
if Mac you'll have to live with a script
geposted Thu 08 May 25 @ 1:36 pm
Which plug in do you use?
geposted Thu 08 May 25 @ 3:09 pm
virtualfx and a .ini to program it.
geposted Thu 08 May 25 @ 3:21 pm
