I often, will mix original videos with live versions of the same song. I have to adjust the pitch on one to match the other for smooth transitions between the 2 videos. I have no problems with that, however with unload the video with the adjusted pitch and reload it, it resets back to zero. I wish Virtual DJ would remember the settings for the pitch, like it remembers the hot cues.
geposted Thu 05 Jun 25 @ 3:44 pm
If the BPM is scanned correctly on both, can you not just hit the sync button?
geposted Thu 05 Jun 25 @ 4:03 pm
resetPitchOnLoad=no
Remembering a pitch position setting persistently + indefinitely like a cuepoint imo doesn't make much sense to me - the pitch is normally used to match with the BPM of something else in another deck. If that is what you want, it probably could be done by saving some info to the track tag that's consulted in ONLOAD via vdjscript, but still, could you explain why you would want that?
geposted Thu 05 Jun 25 @ 4:04 pm
