I just purchased the VDJ Infinity and i can't get it to download i can't get an OEM i can't RECORD and of my new mixes and i can't even get the link to do ANYTHING please Help me find all these things so i can get my Groove on I have been using VDJ for many years
geposted Mon 16 Jun 25 @ 4:46 pm
Download VirtualDJ installer from here .. https://www.virtualdj.com/download/index.html
Do you get the file fully downloaded ?
Install VirtualDJ from the file you downloaded. Does the installation complete successfully or get any errors (define what) ?
Do you get VirtualDJ opened after installation or do you get any error ? Define what.
what do you mean by OEM ?
Are you trying to use/connect some MIDI controller ? which one ?
geposted Mon 16 Jun 25 @ 5:02 pm
