I'm trying to get an LED on my controller to light up IF the mic is on.
Is there a variable to check this against?
Thanks
Thanks
geposted Tue 17 Jun 25 @ 5:35 am
depends on the controller, most controllers leave all mic stuff to the hardware to avoid the latency. If vdj is aware there is a mic then the verb to query is
mic
mic
geposted Tue 17 Jun 25 @ 6:55 am
mic
mic
Thanks - that worked. I guess the Hercules Inpulse 500 doesn't have that issue.
geposted Wed 18 Jun 25 @ 12:04 am
