Is there a way of saving the FX for each controller?
So I have my Denon MC6000 mk2, which I mainly use.
However occasionally I use a Prime go or a prime go+
Strangely the same fx are not available on both ?
Are the FX VDJ fx or the fx of the controller?
But for example, if I have my FX setup perfectly for my MC6000 mk2, how do I save those settings, so if I use it after the prime go it is "saved" or back to how i like it?
So I'd like to save that - strangely the SAVE feature under controller doesn't save the FX settings.
geposted Mon 30 Jun 25 @ 10:50 pm
