I love the 'Key Difference' column along with VirtualDJ key matching, and wondered if you were able to expand on that idea to indicate whether a track is a distinct jump UP or DOWN keys when it won't key match, so when your trying to lift the mood for example, you can easily spot tracks that will do just that.
I know I could just display the actual Key column and work it out but was thinking more of something that is easy to see at a glance, and maybe incorporate in the Key Diff column when tracks won't key mix anyway to save space.
This may be musically impossible anyway from a programming point of view but just thought I would put the idea out there, or equally it may already exist and I just don't know about it considering how powerful VDJ is, if so just let me know.
Thanks
Thanks
geposted Sat 05 Jul 25 @ 8:42 pm
