Discussion about XP2-GRV6
geposted Mon 07 Jul 25 @ 1:13 am
Pad 1 - 4: Select the Stem Part which is used for the Groove Circuit
Pad 5 - 8: Roll Effect is used to the selected Stems (Smart Pressed=short selection toggles the effect, long pressed uses effect as long as you hold the pad)
Pad 9: with Toggle on the roll/trans effect is used without smartpressed
Pad 11 - 12: Brake FX for selected stems only, Pad 11 is only while Pad is pressed, Pad 12 toggles on/off (requires FX "VinylBrake")
SHIFT + Pad 1 - 4: Select FX processing for muted stems: 1 Echo Out, 2 Cut/Trans, 3 Braker, 4 Delay
SHIFT + Pad 5 - 8: Trans Effect is used to the selected Stems (Smart Pressed=short selection toggles the effect, long pressed uses effect as long as you hold the pad)
SHIFT + Pad 9: with Toggle on the roll/trans effect is used without smartpressed
SHIFT + Pad 11 - 12: Brake FX for selected stems only, Pad 11 is only while Pad is pressed, Pad 12 toggles on/off (requires FX "VinylBrake")
geposted Mon 07 Jul 25 @ 11:46 am
