In the drop down menu I wish I had the ability to batch analyze multiple bpm files "Analyze for BPM ETC" maybe in the menu there can be an option to analyze multiple. I find that I'm using analyze bpm multiple a lot for songs that have 100-128 transitions, it would be nice to not have to go into the BPM editor to do. this simple task. Thanks! Also the BPM engine is like 9/10 really helpful thank you!
geposted Sun 20 Jul 25 @ 8:11 pm
Add the following to a custom button and you can get the behavior on custom button press once you load the track to the deck:
It would be nice to have it in the context menu though for browsed songs (by default).
reanalyze multi
geposted Sun 20 Jul 25 @ 8:23 pm
Thats a nice work around. I'm going to use that but we need the official feature please and thanks!
geposted Tue 22 Jul 25 @ 10:03 am
I mapped it to CTRL-A and it works brillilant, even for multiple files when selected.
geposted Tue 22 Jul 25 @ 12:23 pm
