I am using a Windows 11 HP computer. I have been having problems with my DDJ RR audio. When I plug in the controller, I am unable to access my files and cannot use the controller at all. I don't know if it is an ASIO or WASP problem. Could someone from support please help me. Thanks
geposted Mon 21 Jul 25 @ 10:39 pm
DJJQ15 wrote :
...with my DDJ RR audio. When I plug in the controller, I am unable to access my files and cannot use the controller at all.
So you re saying that the sound card of the DDJ-RR disappears your Files from the VDJ Browser ?!?
Do you still control Volume faders, Pitch faders and all Midi functions from the controller and it's just a matter of Audio output ?
What if you remove the "linein 1" and "linein 2" entries of the default audio Setup ? https://virtualdj.com/image/big/97601/196171/audio%20setup.png
Nr.7 SELECT SOURCE https://virtualdj.com/manuals/hardware/pioneer/ddjrr/layout/mixer.html ar properly set to Decks 1/3, 2/4 ?
Also take a look at the PCMIX mode and RB Mode notes in the Manual, just in case you figure it out. https://virtualdj.com/manuals/hardware/pioneer/ddjrr/inputs.html
geposted Tue 22 Jul 25 @ 1:28 pm
Thank you so much. I will review all the links you provided and get back to you.
geposted Wed 23 Jul 25 @ 1:26 am
