Hi!
I use VSCode to edit my VDJ skin files. Is there a simple linting tool available? I tend to make litlle mistakes, like forgetting a space before ? in a conditional statement, or making up verbs that are similar to the right ones... Sometimes, it takes extensive testing to find a bug, and it could be long to trace it's source too.
Is there a linting tool available? Do you have other tricks to perform the same function?
Thanks!
Thanks!
geposted Mon 11 Aug 25 @ 4:49 pm
