Forum: Addons
Topic: Traktor Kontrol S5 Screens
geposted Fri 15 Aug 25 @ 10:25 pm
Will work on one of my PCs but not the other. Same version of VDJ. Will link to the S5 but no screen on the controller
Displays don't work on any of my 3 PCs. (Win10/Win11)
The behavior is consistent across all three devices with ASIO driver installed and without. No change after installing Native Access, and it says all devices are up to date there, though no devices are listed. I have both a Traktor Kontrol S3 and the S5 connected at the moment. Not sure if they should be displayed there or not when up to date.
Can you try ...
- Having only the S5 connected ?
- Can you try to also install Traktor (any version would do) and see if works there and then check VDJ again ?
PS. Can you also check if the file Traktor Kontrol S5 Screens.zip exists in /VDJHomeFolder/Skins ?
To open VDJ Home Folder ... https://www.virtualdj.com/img/370573/29893/Options.png
Looks like it needed one of the other drivers from Traktor Pro 4! Screens are working now after installing it. Thank you!!
can you help me?
I mapped 'Snap' button to toggle between EQ & Stems mode
my issue is light feedback is stays the same, i wanted to light to be on 100% when Stem mode is active.. please help, i can't figure out
this is my mapping script:
eq_mode +1
Stock LED mapping defaults to following button script, button script you've used isn't queryable.
Solution: Give LED_Snap entry a script it can query.
how to do that? I'm absolutely a noob.. sorry for not understanding, appreciate if you can help me
Since you're toggling between freq mode and some other mode ez/mod/full, easiest is use this as a your query
not eq_mode frequency
nothing happens
Well it's for you to figure out then, I don't have the hardware.
Change the SNAP button action to ..
eq_mode 'frequency' ? eq_mode 'moderneq' : eq_mode 'frequency'
then the LED_SNAP should have ..
eq_mode 'moderneq' ? true : false
PS. This topic is about the S5 Screens skin, not generic S5 support or VDJ script.
Please open a new topic if you are about to continue script questions.
Yay! made it working, apologies about script related questions, please remove if you have to...
and thank you so much for the help :)
Hi guys did anyone solve the screen problem ?
