Hi VDJ community...
I was wondering if you’re familiar with the amazing Piano Play feature on the Pioneer DDJ-REV5.
It lets you play a cue point across all 16 pads like a piano keyboard, creating really cool transitions. You can also select the cue point and choose from 5 preset scales.
Does anyone know if something similar has been developed for VDJ, perhaps as a plugin or add-on?
Thanks!
F.
https://www.youtube.com/shorts/vJTfgwRttIA
Thanks!
F.
geposted Thu 21 Aug 25 @ 6:43 am
Check the KeyModPlay pad page from extensions
geposted Thu 21 Aug 25 @ 7:02 am
Checked it's not the same unfortunately...but thanks!
geposted Thu 21 Aug 25 @ 7:17 am
how does it differ? Can you just make it yourself?
geposted Thu 21 Aug 25 @ 8:55 am
I would if i could...luckily the pad creator replied to my question in the pad page comment section saying he did it already abd soon he will upload it!
geposted Thu 21 Aug 25 @ 8:58 am
Available now .. https://virtualdj.com/forums/265143/Addons/Piano_Play.html
geposted Thu 21 Aug 25 @ 11:36 am
WOW...I always say VDJ community is the best!!! Thanks!
geposted Thu 21 Aug 25 @ 11:38 am
