I ve synced my library on clouddrive (onedrive) and i am facing 2 problems.
Problem 1: my library has 6033 tracks all with their stems and on clouddrive are appearing 5928 tracks
Problem 2: From the pc i synced to if i add a track to the folder it does not sync to clouddrive neither i get force sync option on clouddrive folder as the manual says.
Any suggestions on how to come around these?
Ps. On options there is a clouddrive sync key. This is particular on the specific pc or i can copy it to another pc and carry on syncing from there?
geposted Thu 21 Aug 25 @ 8:48 pm
