Anyone here using the Android version of the Virtual DJ Remote? I have a wifi question. Can I use a router that is not attached to the internet but will allow the phone to connect to the laptop?
geposted Sun 24 Aug 25 @ 12:40 am
Yes
geposted Sun 24 Aug 25 @ 6:53 am
You can use something like Connectify to create an access point from your laptop if needed too.
geposted Sun 24 Aug 25 @ 10:38 am
On Windows 11 creating a hotspot is built in too, without need for additional software.
geposted Sun 24 Aug 25 @ 12:53 pm
You can hotspot from your phone (at least I've done it on Android) and MacBooks as well.
geposted Sun 24 Aug 25 @ 2:38 pm
For me it only works with an Internet connection. If none is available then the hot-spot function is greyed out hence why I use Connectify.
geposted Sun 24 Aug 25 @ 2:39 pm
It is true, hotspotting is meant to share your internet connection, but most ppl have data plans so it may not be an issue.
I would think once you can turn a device into a connectable/accessible router/gateway that doesn't block the required port(s), and you setup the machine running VirtualDJ and the mobile device running VirtualDJ remote to use that router/gateway, it should work.
geposted Sun 24 Aug 25 @ 2:51 pm
Since the update of 08/31/2025 my dj remote (Android) not working. :(
geposted Mon 01 Sep 25 @ 12:16 am
